Holes with small bump in perimeter
Posted by botbuilder
March 12, 2014 10:33PM
Using Slic3r v0.9.10b and a newly built SmartRap printer (Bowden with Huxley hotend)
Using 1.75 PLA initial layer temp = 200, following layers 190.
All of my holes have this small imperfection. Seems like the larger the hole, the larger the bump.
Can this be fixed in the slicer?
open | download - HoleswithBumps.jpg (101.9 KB)
Re: Holes with small bump in perimeter
March 13, 2014 12:29PM
Try Retraction ...In Printer Setting ..extruder ... retraction
March 13, 2014 02:19PM
Here are my retraction settings:
retract_before_travel = 2
retract_layer_change = 1
retract_length = 3
retract_length_toolchange = 10
retract_lift = 0
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 37
Bowden cable is 360mm long with a MK7 gear.
I'm new to reprap...what would be a good recommendation?
March 13, 2014 02:42PM
I am new too .. smiling smiley
We have similar settings as i can see ..
try to raise up a little you retract speed
Have you make calibration to your E- steps? if not this is a very good guide [reprap.org]
March 13, 2014 03:40PM
I'm using a 600mm Bowden tube and E3D hotend with Cura as the slicer, and have it set for 4.5mm retraction and 100mm/second retraction speed with PLA. Not that these are magic numbers by any means, but the retraction speed is three times what you have set.....
March 13, 2014 06:47PM
I used this utility (http://www.buildlog.net/gview/index.html) to see the entire gcode model rendered along with toolpaths. I could see that the toolpath crossed the hole right at the nub locations.
Per your advise, increased retract length and speed and the hole was completely clean. Even passed the double xy nickel test perfectly on the first try.
Thanks!
