Hi everybody,
I'm printing "things" since beginning of the year. The Kossel Mini is my first and only 3D printer so far. I like the design and the way it moves, and the print results.
Normally the 170mm square print surface is enough for the most builds, but sometimes If I want to print something larger, I've to rotate the object 90° to print it vertical instead of horizontal. It works for the most objects. But especially for housings I need very much support. More than 50% of the used material goes for the support. E.g.: [
www.thingiverse.com] This is the object I try to print. But there is too much space between the walls. Is there anything I can do to print it with less support?
