Z min always triggers TRIGGERED October 16, 2014 03:30PM |
Re: Z min always triggers TRIGGERED October 16, 2014 05:16PM |
Re: Z min always triggers TRIGGERED October 16, 2014 06:06PM |
Re: Z min always triggers TRIGGERED October 16, 2014 07:41PM |
Re: Z min always triggers TRIGGERED October 16, 2014 11:28PM |
Re: Z min always triggers TRIGGERED October 16, 2014 11:32PM |
I understand that difference. I am talking about the pullups. To me, it looks like a conditional that does the same thing for both conditions.Quote
ggherbaz
The first part, the bold ones indicate that you set the endstops pull up for all endstops, that is right as long as you have mechanical switches or any switch that will allow voltage to ground (some switches already has them)and they are set so you don't create a short circuit. the second part, the one with yellow letters is the one that controls the logic (NC or NO).
If you want to understand it better, you can play with your switches. You got them all as true, now do an M119 code and switch to false any one showing triggered (without been actually triggered) after that repeat M119 and all should say open, trigger one with your fingers and run M119 again, the one you are holding will display "triggered".
Re: Z min always triggers TRIGGERED October 16, 2014 11:41PM |
Re: Z min always triggers TRIGGERED October 16, 2014 11:56PM |
Re: Z min always triggers TRIGGERED October 17, 2014 12:01AM |
Re: Z min always triggers TRIGGERED October 17, 2014 12:04AM |
Do you use marlin with an inductive sensor?
Re: Z min always triggers TRIGGERED October 17, 2014 12:06AM |
Re: Z min always triggers TRIGGERED October 17, 2014 12:07AM |
Re: Z min always triggers TRIGGERED October 17, 2014 12:08AM |
Re: Z min always triggers TRIGGERED October 17, 2014 12:13AM |
Re: Z min always triggers TRIGGERED October 17, 2014 12:14AM |
Re: Z min always triggers TRIGGERED October 17, 2014 01:18AM |
Re: Z min always triggers TRIGGERED October 18, 2014 05:26PM |
Re: Z min always triggers TRIGGERED October 22, 2014 03:35AM |
