Another clogged HE! March 13, 2016 06:50PM |
Re: Another clogged HE! March 13, 2016 07:55PM |
Re: Another clogged HE! March 14, 2016 02:21AM |
Re: Another clogged HE! March 14, 2016 02:32AM |
Re: Another clogged HE! March 14, 2016 02:38AM |
Re: Another clogged HE! March 14, 2016 03:36AM |
Re: Another clogged HE! March 14, 2016 04:17PM |
frankvdh
Maybe its some kind of heat creep. It may take a while for the heat to creep from the nozzle up the heat break and then to soften the filament enough to jam. Maybe you've just been lucky with the other filament.
So, some basic questions to cover the obvious (a photo would probably help too)...
I take it that you do have a fan on the heatsink? And that it is on all the time? With a good shroud around the heatsink? And that it is positioned at the bottom of the heatsink?
Does your hot-end have a PTFE liner? After many hours of experimenting with PLA in an unlined Chinese "E3DV6", I gave up and replaced it with a lined one. Like magic, the problems all went away.
The last thing you could try is a total experiment. In theory, your heatsink fan should be more efficient if it sucks hot air away from the heatsink, rather than blowing cold air onto it. I now have my fan switched to "suck", and it works fine. But I think the total sample size of this experiment is so far 1.
Re: Another clogged HE! March 15, 2016 03:16PM |
Re: Another clogged HE! March 16, 2016 05:05PM |
Re: Another clogged HE! March 16, 2016 06:35PM |
Re: Another clogged HE! March 17, 2016 01:25AM |
Re: Another clogged HE! March 17, 2016 02:24AM |
Re: Another clogged HE! March 17, 2016 05:48AM |
Re: Another clogged HE! March 18, 2016 02:09AM |
Downunder35m
I still do all my prints without but here in AU I usually only suffer from too hot temps and not suck much from low temp problems.
But from what I have tried so far I have to say that really big parts, considering my 300x260x200 build volume, benefit from an enclosure or at least a big bag over the printer to keep the temp evenly inside.
12h plus prints usually encounter changing room temperatures to some degree and if it is more than 5or8 it can be enough to show in the print.
Re: Another clogged HE! March 20, 2016 08:46AM |
Re: Another clogged HE! March 20, 2016 10:21AM |
Re: Another clogged HE! March 20, 2016 05:51PM |
