Dreadnaught426
My E-steps are dead on.
How did you determine that? The definition of well calibrated e-steps is that solid infill has no gaps and no bumps/ridges. Everything else just gets you in the ballpark. (ok, I admit that's an arguable point. If you're printing single walled vases then perhaps the width of the wall is the more appropriate measure of accurate extrusion)
First layer is at 200% in extrusion width.
Slic3r uses % of layer height for widths, which I find unhelpful. I prefer to set a fixed width in mm and typically use a wider width for the first layer than for the remaining layers. Changing the width should have no impact on over/under extrusion as the volume is calculated accordingly.
Also, in Overlap the Infill/Perimeters overlap is at 15%. Normal or nott?
Normal, but potentially the cause of over-extrusion on small models where fill is comprised of many short segments. You can try reducing this a little but watch out for the infill becoming less well attached to the perimeters.
