Speed vs Tempreture and a tale of frustration. September 13, 2016 07:00AM |
Re: Speed vs Tempreture and a tale of frustration. September 13, 2016 07:53AM |
Re: Speed vs Tempreture and a tale of frustration. September 13, 2016 08:21AM |
Re: Speed vs Tempreture and a tale of frustration. September 13, 2016 08:25AM |
Mongrel_Shark
I thought I'd re print some of the last fer g.codes to see if day vs night temps really had that much effect.
[attachment 83787 DSCN4881.resized.JPG] [attachment 83788 DSCN4882.resized.JPG]
[attachment 83789 DSCN4884.resized.JPG]
Could this be related to my problem??
Re: Speed vs Tempreture and a tale of frustration. September 13, 2016 12:02PM |
Re: Speed vs Tempreture and a tale of frustration. September 13, 2016 01:43PM |
Re: Speed vs Tempreture and a tale of frustration. September 13, 2016 04:07PM |
Re: Speed vs Tempreture and a tale of frustration. September 13, 2016 07:37PM |
Re: Speed vs Tempreture and a tale of frustration. September 13, 2016 07:58PM |
Re: Speed vs Tempreture and a tale of frustration. September 13, 2016 10:36PM |
Re: Speed vs Tempreture and a tale of frustration. September 13, 2016 10:59PM |
Re: Speed vs Tempreture and a tale of frustration. September 13, 2016 11:26PM |
Re: Speed vs Tempreture and a tale of frustration. September 14, 2016 12:52AM |
the_digital_dentist
Why does it extrude fast better than slow?
Maybe when filament is moving through the extruder fast the heat can't creep up the throat and cause it to jam...
With all the mechanical problems I think anything could happen. Once the mechanical stuff is sorted out you can try again and maybe all the mysteries will have disappeared.
Re: Speed vs Tempreture and a tale of frustration. September 14, 2016 01:55AM |
Re: Speed vs Tempreture and a tale of frustration. September 14, 2016 07:37AM |
Re: Speed vs Tempreture and a tale of frustration. September 14, 2016 07:12PM |
Re: Speed vs Tempreture and a tale of frustration. September 14, 2016 08:51PM |
Re: Speed vs Tempreture and a tale of frustration. September 14, 2016 10:34PM |
Floyd
Your trying to extrude at 120-130c?
Bump that up a bit. Ive even tried PLA that needed 210c to print right.
I thought most people print PLA from 180-210c 120c seems REAL low. Might be giving yourself jams from trying to cram PLA into the nozzle without it being melted fully.
Re: Speed vs Tempreture and a tale of frustration. September 15, 2016 04:32AM |
Re: Speed vs Tempreture and a tale of frustration. September 15, 2016 04:41AM |
Re: Speed vs Tempreture and a tale of frustration. September 16, 2016 07:27PM |
MechaBits
you linked to a $119 e3d, yet the shop that has the hexagon also has e3d clone for $19
throats & nozzles are cheap, whats your time worth.
Re: Speed vs Tempreture and a tale of frustration. September 16, 2016 08:27PM |
Re: Speed vs Tempreture and a tale of frustration. September 17, 2016 01:17AM |
Re: Speed vs Tempreture and a tale of frustration. September 17, 2016 01:36AM |
Re: Speed vs Tempreture and a tale of frustration. September 17, 2016 03:43AM |
Re: Speed vs Tempreture and a tale of frustration. September 17, 2016 03:48AM |
Re: Speed vs Tempreture and a tale of frustration. September 17, 2016 04:16AM |
Re: Speed vs Tempreture and a tale of frustration. September 17, 2016 06:02AM |
Re: Speed vs Tempreture and a tale of frustration. September 17, 2016 07:48AM |
Re: Speed vs Tempreture and a tale of frustration. September 17, 2016 08:50AM |
