Wobbly lines in lower layers March 21, 2017 05:39PM |
Re: Wobbly lines in lower layers March 21, 2017 07:07PM |
Re: Wobbly lines in lower layers March 21, 2017 07:59PM |
Re: Wobbly lines in lower layers March 23, 2017 01:12PM |
Re: Wobbly lines in lower layers March 23, 2017 01:58PM |
Re: Wobbly lines in lower layers March 23, 2017 03:10PM |
Re: Wobbly lines in lower layers March 24, 2017 10:53AM |
Re: Wobbly lines in lower layers March 24, 2017 02:45PM |
Re: Wobbly lines in lower layers March 25, 2017 03:27AM |
the_digital_dentist
Yes, a cooling fan is very useful and improves print quality.
Flexible feet are good to minimize noise if your printer's frame is very rigid. If it isn't, soft feet are the last thing you want. If your printer's frame is flexy you need to set it directly on a hard, flat surface because that surface is part of the printer and helps keep things mechanically aligned.
Re: Wobbly lines in lower layers March 25, 2017 09:36AM |
Re: Wobbly lines in lower layers March 25, 2017 10:27AM |
Re: Wobbly lines in lower layers March 25, 2017 05:55PM |
Re: Wobbly lines in lower layers March 27, 2017 11:36AM |
