Cura End code problem April 15, 2018 02:16PM |
M104 S0 ;extruder heater off M140 S0 ;heated bed heater off (if you have it) G91 ;relative positioning G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure G1 Z+20 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more G28 Y0 ;move X/Y to min endstops, so the head is out of the way G28 X0 ; M84 ;steppers off G90 ;absolute positioning
Re: Cura End code problem April 16, 2018 02:28AM |
Re: Cura End code problem April 16, 2018 02:41AM |
o_lampe
Isn't it G28 Y, not Y0?
Why do you home the printer and not just send G1 Y0 F###?
Re: Cura End code problem April 16, 2018 03:29AM |
Re: Cura End code problem April 16, 2018 03:42AM |
Re: Cura End code problem April 16, 2018 05:22AM |
o_lampe
It's not Curas fault, but Marlins. It only reads G28 and ignores whats written behind. I'm sure, it just homed the printer twice, always beginning with X-axis.
Re: Cura End code problem April 18, 2018 08:00AM |
Re: Cura End code problem April 18, 2018 09:03AM |
MCcarman
Just looking for issues.
Your in relative positioning - maybee you can't home in relative.
You can always load the Gcode in a text editor (notepad etc) and scroll to the end and check the actual code in the file.
Re: Cura End code problem April 18, 2018 04:12PM |
