Nozzle Dragging Through The Print August 12, 2018 12:22PM |
Re: Nozzle Dragging Through The Print August 12, 2018 01:02PM |
Admin Registered: 16 years ago Posts: 13,895 |
Re: Nozzle Dragging Through The Print August 13, 2018 02:19AM |
Re: Nozzle Dragging Through The Print August 13, 2018 03:16AM |
Re: Nozzle Dragging Through The Print August 13, 2018 03:41AM |
Re: Nozzle Dragging Through The Print August 13, 2018 04:34AM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: Nozzle Dragging Through The Print August 13, 2018 04:49AM |
I never go bigger than 0.3mm layer heights. Usually print at 0.2mm.Quote
Dust
layer heights should not be more than 80% of nozzle diameter... with a .4 that is 0.32 layer heights.
Dust
Have you measured your filament diameter and entered that correctly into the slicer?
Dust
Have you calibrated your Extruder steps/mm? So that when you ask the machine to take in 100mm it really does take in 100mm of filament?
Re: Nozzle Dragging Through The Print August 13, 2018 05:50AM |
OldJanmi
Dust
Re: Nozzle Dragging Through The Print August 13, 2018 07:07AM |
Re: Nozzle Dragging Through The Print August 13, 2018 08:53AM |
Re: Nozzle Dragging Through The Print August 13, 2018 10:37AM |
Re: Nozzle Dragging Through The Print August 13, 2018 12:23PM |
Re: Nozzle Dragging Through The Print August 13, 2018 12:45PM |
Re: Nozzle Dragging Through The Print August 13, 2018 10:40PM |
Re: Nozzle Dragging Through The Print August 13, 2018 10:48PM |
Re: Nozzle Dragging Through The Print August 13, 2018 11:12PM |
Re: Nozzle Dragging Through The Print August 14, 2018 07:25AM |
Re: Nozzle Dragging Through The Print August 14, 2018 07:31AM |
Re: Nozzle Dragging Through The Print August 15, 2018 12:35AM |
Re: Nozzle Dragging Through The Print August 15, 2018 09:33AM |
Re: Nozzle Dragging Through The Print August 15, 2018 10:12PM |
