Problem in Auto bed leveling
Posted by Baalaji V
October 01, 2018 02:23AM
Greetings to all! I have to set auto bed leveling in my 3d printer. I have placed inductive sensor in it. The problem is when I give homing command, XY axis homing is done but while Zaxis homing. eventhough the sensor is ON, the Z axis moves down rather to stop.
I use 6-36V inductive sensor. Which is connected by voltage regulator.
And also once the Zmin gets TRIGGERED, it is always TRIGGERED. The voltage across the sensor is 10.37V
Configuration.h
Please help me in this.
Thanks in advance
Baalaji
Edited 3 time(s). Last edit at 10/01/2018 05:38AM by Baalaji V.
Re: Problem in Auto bed leveling
October 01, 2018 02:49PM
Sometimes when Inductive probes are mounted with metal or close to metal they can respond this way.
Can you show a picture of the mounted probe, and if it close to any metal that could keep the sensor from resetting to open.
It could also be wiring show sensor wiring diagram and sensor type.
Edited 1 time(s). Last edit at 10/01/2018 02:51PM by Roberts_Clif.
