Motor moving slowly after failed firmware upgrade December 13, 2018 01:43PM |
avrdude: verifying ... avrdude: verification error, first mismatch at byte 0x3e000 0xff != 0x0d avrdude: verification error; content mismatch
avrdude: Device signature = 0x1e9801 (probably m2560) avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: Using SCK period of 10 usec avrdude: reading input file "C:\Users\MARTIN~1.VEL\AppData\Local\Temp\arduino_build_121131/Marlin.ino.hex" avrdude: writing flash (151992 bytes): Writing | ################################################## | 100% 243.24s avrdude: 151992 bytes of flash written avrdude: verifying flash memory against C:\Users\MARTIN~1.VEL\AppData\Local\Temp\arduino_build_121131/Marlin.ino.hex: avrdude: load data flash data from input file C:\Users\MARTIN~1.VEL\AppData\Local\Temp\arduino_build_121131/Marlin.ino.hex: avrdude: input file C:\Users\MARTIN~1.VEL\AppData\Local\Temp\arduino_build_121131/Marlin.ino.hex contains 151992 bytes avrdude: reading on-chip flash data: Reading | ##################An error occurred while uploading the sketch
Re: Motor moving slowly after failed firmware upgrade December 13, 2018 04:55PM |
Re: Motor moving slowly after failed firmware upgrade December 13, 2018 10:44PM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Motor moving slowly after failed firmware upgrade December 13, 2018 10:48PM |
Re: Motor moving slowly after failed firmware upgrade December 14, 2018 01:48AM |
Re: Motor moving slowly after failed firmware upgrade December 14, 2018 02:09AM |
Re: Motor moving slowly after failed firmware upgrade December 14, 2018 07:19AM |
Re: Motor moving slowly after failed firmware upgrade December 14, 2018 11:16AM |
