Printer won't extrude with 0.1mm layers? June 22, 2019 04:49PM |
Re: Printer won't extrude with 0.1mm layers? June 22, 2019 10:39PM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Printer won't extrude with 0.1mm layers? June 24, 2019 09:01AM |
Re: Printer won't extrude with 0.1mm layers? June 24, 2019 12:32PM |
Sounds like a nozzle jam.Quote
aflactheastronaut
I temporarily raised the nozzle offset just to check that. The nozzle was 2mm away from the bed, but it still wasn't extruding plastic. The motor was still twitching too
Re: Printer won't extrude with 0.1mm layers? June 24, 2019 12:54PM |
Re: Printer won't extrude with 0.1mm layers? June 24, 2019 08:55PM |
Re: Printer won't extrude with 0.1mm layers? June 24, 2019 08:57PM |
Re: Printer won't extrude with 0.1mm layers? June 25, 2019 12:11AM |
Re: Printer won't extrude with 0.1mm layers? June 25, 2019 09:34AM |
Re: Printer won't extrude with 0.1mm layers? June 25, 2019 10:52PM |
Re: Printer won't extrude with 0.1mm layers? June 25, 2019 11:04PM |
Re: Printer won't extrude with 0.1mm layers? June 27, 2019 12:09PM |
aflactheastronaut
It worked! With an extrusion multiplier of 150% on the first layer, it turned! And then it kept turning, even when it had moved onto higher layers!
It must be a minimum extruder steps/G1 command or something. I've never run into it before, but now I know what to expect. Thanks guys for helping!
May your lines be straight and your nozzles never clog,
Aflactheastronaut
