I have just added a bltouch to my printer and i can not get it to level one corner propperly 97% of the time, i have occasionally got an abl were they are all fairly level but i cant find a difffrent from my normal bed levels because as soon a i redo the auto leveling the back right corner is low again. The back rigth corner is consistently lower then the other three (see pics). I have been trying to fix this for the past 3-4 day and im out of ideas and have not made any progress. If you need more info let me know and thanks for any help.
Process for leveling:
Heat bed and hot end (All so tried Cold)
G28
G29
M500
Print gcode:
G28
M420 S1 ; Load saved Bed Levels
Other thing i have tried:
Moving the bltouch closer to the hot end (no change)
Making sure evey thing is level the straight with the frame (no change)
Making the frame unlevel and straight to try and either make it better or worse (no change)
Tried diffrent cables the the controll board (no change)
Tried changing marlin so it turns off the bed heater when leveling (no change)
Changing the bltouch port on the skr board (no change)
Tried diffrent version of marlin 2.0.4.0, 2.0.4.1 , bugfix-2.0.0 (no change)
Tried Bilinear and ubl (Same problem with both)
Manualy re-leving the bed multiple times (no change)
Clearing eeprom (no change)
Loading defaults (no change)
and More i can remember
Other info:
Frame: Malyan M150
extruder: E3d Hermes
Print surface: glass bed
Controller: skr 1.4 turbo
Bltouch 3.1
Marlin 2.0.4.1
configs (Pastebin links):
Configuration |
Configuration_adv
