PLA keep on curling up on exit on extruder head November 03, 2012 11:13PM |
Re: PLA keep on curling up on exit on extruder head November 04, 2012 01:20AM |
Re: PLA keep on curling up on exit on extruder head November 04, 2012 01:25AM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: PLA keep on curling up on exit on extruder head November 04, 2012 05:35PM |
Re: PLA keep on curling up on exit on extruder head November 09, 2012 02:46AM |
Re: PLA keep on curling up on exit on extruder head November 24, 2012 08:22PM |
Re: PLA keep on curling up on exit on extruder head November 24, 2012 10:11PM |
Re: PLA keep on curling up on exit on extruder head November 28, 2012 02:58AM |
Re: PLA keep on curling up on exit on extruder head November 28, 2012 04:33AM |
Re: PLA keep on curling up on exit on extruder head November 29, 2012 09:07PM |
Re: PLA keep on curling up on exit on extruder head November 29, 2012 09:31PM |
Re: PLA keep on curling up on exit on extruder head November 29, 2012 09:51PM |
Re: PLA keep on curling up on exit on extruder head November 30, 2012 11:23PM |
Re: PLA keep on curling up on exit on extruder head December 15, 2012 05:26PM |
sypher
Hi, I remember you from way back when Richard first started launching on Indiegogo. I am having some problem trying to get my system to extrude consistently. I have the first batch of extruder and wondering if that maybe is the problem. Just wondering if you can maybe take a look at my thread that I made on reprap.com below. I have been working on this for over a year now and would appreciate your input. Thanks.
[forums.reprap.org]
Re: PLA keep on curling up on exit on extruder head December 16, 2012 10:22PM |
Re: PLA keep on curling up on exit on extruder head December 17, 2012 08:04PM |
sypher
Hi, can you clarify something? On your blog you mention that the unit came ready and work right out of the box and from the picture on this page, beside the hot bed and hot end, we have the same setup. Could the problem be something else like the heat distributions on the hot end?
syther
When I pull out my filament after letting it cool off a bit, I can see that there is uneven warping on the filament at where the aluminum block is located. Read somewhere that filament need a certain pressure to come out of the hot end and due to the warping/stretching of the filament, there was a gap and what could have cause the problem. Just a theory and would kinda make sense as to why the first couple of layer look great but then it start to trickle filament down.
sypher
I would actually try your version of extruder on thingiverse out but I can't print one myself and they don't ship (ebay alternative work?). Wondering if the one your currently using is the second batch of hotend from Richard because the one on his site look different.
Re: PLA keep on curling up on exit on extruder head December 19, 2012 02:42AM |
Re: PLA keep on curling up on exit on extruder head December 19, 2012 06:49PM |
sypher
Found out that it is often a hit and miss with this system and require a lot of supervision so I am looking forward to your recommendation ASAP. Just curious as to which two kit are you looking at?
Re: PLA keep on curling up on exit on extruder head January 07, 2013 12:11AM |
Re: PLA keep on curling up on exit on extruder head January 08, 2013 06:02PM |
