Most likely you are losing steps on the X axis, probably the stepper pot is set slightly too low.
The kisslicer GCode is probably just different enough to cause this to happen, the speed settings aren't identical for example.
It could also be too high a speed set in the slicer/firmware, and possibly something mechanical, though that seems unlikely if you've been printing successfully.
