QU-BD jamming February 20, 2014 12:35PM |
Re: QU-BD jamming February 24, 2014 10:21PM |
Re: QU-BD jamming February 25, 2014 02:32PM |
That looks like the stock gear.. the MK7 gear is from the makerbot.. it looks like this.Quote
Janski
I too am getting the exact same issue. I have the QU-BD extruder on my Ord Bot printer. Trying to print ABS black at 230 degrees C. the nozzel is .5 diameter.
Shreddin, how long does it usually take for your hotend to heat up? what do you mean by this: made the spring tensioner with a ball bearing.? attached is the gear that i am using. is this the same as the MK7 gear? it seems like the gear I have does not have enough tension to even pull the 1.75 filament down
Any advice from the forum Pros gladly appreciated. Should i just buy a different extruder?
Janski
Re: QU-BD jamming February 25, 2014 02:40PM |
