test cube
Posted by gilsah
test cube
March 01, 2014 08:14PM
Ok so I just ran a 5mm wall test cube and it is 6mm thick? what do I do now?
Re: test cube
March 01, 2014 11:20PM
I'm guessing you mean 0.5mm and 0.6mm? Have you calibrated your extruder steps/mm?
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
Re: test cube
March 03, 2014 02:22PM
I did the calibration on the filament. So when I extrude 20 mm that's the amount of filament it uses.
Re: test cube
March 05, 2014 12:00PM
help , please
I did a filament calibration without the hot end in place
100mm is fed into the extruder so that part I feel is right
However started to do my very first print (the test cube) and the first 4 - 5 layers were a complete mess
Plus I am under the impression, the head moves to home and the filament is supposed to come out and leave a thin line from home to the object
I get nothing, layers 1 and 2 printed nothing 3 - 5 were globs and a huge mess
Is this right is something wrong ??
Thanks in advance
Re: test cube
March 05, 2014 12:11PM
TheBearF8
Please don't hijack other people's threads. However, what you need is the skirt function. This will print some lines around the object before printing the first layer of the object to ensure the hot end is primed.
gilsah
If you are using Slic3r and don't specify an extrusion width but simply enter the nozzle size, it won't produce line widths that are equal to your nozzle size. In fact, you usually want a line width slightly wider than your nozzle size. This isn't a problem unless you really need the line width to be exact, in which case you need to specify the line width directly: [manual.slic3r.org]
Edited 1 time(s). Last edit at 03/05/2014 12:14PM by NewPerfection.
Re: test cube
March 05, 2014 12:16PM
Sorry
Will move to a new topic
