Surface problems
Posted by Capinho
Surface problems
June 19, 2014 03:23PM
Hello everyone. An issue I am facing:
[i59.tinypic.com]
What could cause the red (horizontal) gaps?
About the blue (vertical) texture, I think that is belts problem? I am currently waiting for GT2 belts and pulleys. Am I right about the issue causing this texture?
thanks
Re: Surface problems
June 19, 2014 08:19PM
Red is probably an extruder feed-rate issue. That could definitely be the reason for blue though we would need to know a little more about your printer set up to be sure.
Through self sustaining actions comes freedom
DIY Tech Shop
June 19, 2014 11:50PM
My printer is 3drag. I am using black 3mm PLA, 190 hotend, 60/55 heatbed. Extruder is calibrated for steps/mm. Print speed is 50 mm/s. Extrusion multiplier 0.96. I am using Cura. Layer height 0.25mm, 0.6mm shell thickness. Anything else I could tell you?
Thanks
Edited 1 time(s). Last edit at 06/20/2014 05:56AM by Capinho.
June 21, 2014 06:10AM
Diytechshop correct make sure if you got you plastic on a spool that its coming of correctly without resistance, i was having that problem until i made a spool holder
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
