Hotend too hot?
Posted by Capinho
Hotend too hot?
June 30, 2014 08:22AM
Hello, my print quality became very bad somehow. Prints are now brittle, fragile, not shiny and rough. Could it be hotend too hot? I am printing PLA at 190 degrees. Maybe it is thermistor issue? Thanks.
[fbcdn-sphotos-h-a.akamaihd.net]
Re: Hotend too hot?
June 30, 2014 08:34AM
Too cold.
Also, you might recheck your steps/mm and adjust your extrusion ratio [ie, my printer has proper steps/mm, but when printing with PLA the ext. ratio needs to be 0.9]
Realizer- One who realizes dreams by making them a reality either by possibility or by completion. Also creating or renewing hopes of dreams.
"keep in mind, even the best printer can not print with the best filament if the user is the problem." -Ohmarinus
Re: Hotend too hot?
June 30, 2014 08:51AM
Thanks for quick reply. Extrusion steps/mm are calibrated, I get exactly 100 mms extruded after I request 100 mms. I was printing with same settings before, everything was ok, could it be thermistor? Or maybe the end of the plastic roll, so the PLA quality became worse?
Re: Hotend too hot?
June 30, 2014 11:59AM
Personally, I don't believe in aged PLA or ABS filament. I've stored mine in not a single clean or kept dry environment, just sat in whatever living room of the time. Over a year old and printing hasn't changed.
Could very well be that is the end of the roll though, not because of age but because of a bad manufacturer. Have you tried with a different roll or do you only have one?
Re: Hotend too hot?
June 30, 2014 12:31PM
MrDoctorDIV
Just checked with another PLA, it is the same brittle print. Could it be my thermistor on the hot end shortening, because of poor isolation, so it shows not actual values? Or my heater cartridge broken in some way? In temperature graph, I see actual values, everything seems to be fine.
Edited 1 time(s). Last edit at 06/30/2014 12:40PM by Capinho.
Re: Hotend too hot?
June 30, 2014 01:46PM
Do you have an IR thermometer to verify temps? Have you checked the resistance in your thermistor?
Re: Hotend too hot?
June 30, 2014 02:04PM
MrDoctorDIV
I will get the IR thermometer tomorrow, the resistance in thermistor is ok ( 80-100 kOhms)
