Inserting components in a print September 03, 2015 04:58PM |
Re: Inserting components in a print September 04, 2015 03:39AM |
Re: Inserting components in a print September 04, 2015 10:36AM |
Re: Inserting components in a print September 04, 2015 10:51AM |
Nuts are just an example. Heat inserting after printing will leave the the nut visible from the outside which is precisely what I want to avoid. I thought that people would use a sort of "lift and hop" function for the head to to avoid inserts' protruding areas.Quote
Kurzaa
As for nuts, depending on the final design, I find it is better to heat up a soldering iron to melt the nut into the cavity provided for it then to mess with pausing the mid print and hoping everything fits.
Re: Inserting components in a print September 04, 2015 08:07PM |
Re: Inserting components in a print September 04, 2015 09:27PM |
Re: Inserting components in a print September 04, 2015 10:55PM |
Re: Inserting components in a print September 05, 2015 05:33AM |
AlexY
That method wont work if you're trying to embed a hex nut perpendicular to the bed, since the top gets narrower.
Re: Inserting components in a print September 07, 2015 11:32AM |
