First print issues June 16, 2016 11:31AM |
Re: First print issues June 16, 2016 04:07PM |
Re: First print issues June 16, 2016 10:44PM |
Re: First print issues June 17, 2016 06:38AM |
Re: First print issues June 17, 2016 07:27PM |
Re: First print issues June 18, 2016 06:59PM |
Re: First print issues June 19, 2016 06:38PM |
Re: First print issues June 19, 2016 10:48PM |
Re: First print issues June 20, 2016 12:03AM |
Re: First print issues June 20, 2016 02:34AM |
Re: First print issues June 20, 2016 10:51AM |
frankvdh
140mm is a mighty big fan! Do you mean 40mm?
Looking at the photo, I'd say there's some step skipping in the Y axis, particularly about 1mm or so from the top.
The gaps between infill and perimeters I'd put down to play in the X and/or Y axes... each time the axis reverses direction when printing the infill it will leave a gap.
You might also want to look at your speeds and accelerations... over-accelerating can cause the same kind of thing. I'd start with slow speeds and only speed it up when that's working OK.
To get started, you could just make a simple duct out of folded cardboard and tape. It's only got to hold together for one print. When printing a duct, it doesn't have to be perfect. You can always tape over the holes and hot-glue it in place whilst you print your next duct.
Re: First print issues July 27, 2016 10:25AM |
