print warping midprint January 17, 2017 10:04PM |
Re: print warping midprint January 17, 2017 10:20PM |
Re: print warping midprint January 18, 2017 08:15PM |
Re: print warping midprint January 18, 2017 08:59PM |
Re: print warping midprint January 27, 2017 10:53PM |
anvoice
There's a number of options. You can turn cooling off in the slicing software (at least in Slic3r). You can modify the gcode files directly to turn the fan on and off. Or you can send M107 (fan off) to the printer to turn the fan off. M106 will turn it back on.
If you want to go the Slic3r route, there's a "Filament Settings" tab, there click the "Cooling" icon, which will let you adjust the fan options. You can make the fan speed 0 which will disable it, but you can keep the "Bridges fan speed" at a nonzero value to allow for bridging with the fan on.
