Nozzle hits the prints but bed is leveled April 04, 2020 06:17PM |
Re: Nozzle hits the prints but bed is leveled April 04, 2020 07:50PM |
Re: Nozzle hits the prints but bed is leveled April 04, 2020 10:24PM |
Re: Nozzle hits the prints but bed is leveled April 05, 2020 09:28AM |
/** Allen Key Probes, Servo Probes, Z-Sled Probes, FIX_MOUNTED_PROBE, etc. * Activate one of these to use Auto Bed Leveling below. */ /** * A Fix-Mounted Probe either doesn't deploy or needs manual deployment. * (e.g., an inductive probe or a nozzle-based probe-switch.) //#define FIX_MOUNTED_PROBE
Re: Nozzle hits the prints but bed is leveled April 05, 2020 05:21PM |
Re: Nozzle hits the prints but bed is leveled April 05, 2020 10:44PM |
bornlivedie
I don't really think that applies to my setup, since I don't have a probe installed.
Sorry I forgot to mention I have M501 and M420 S1 right after G28. I also tried putting it right after the last G29. Same results.
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
#define RESTORE_LEVELING_AFTER_G28
bornlivedie
The temporary solution I found is to use Baby Steps,
bornlivedie
I have to set it to something like 0.050 while others require that I set it to 0.350 or more. That's a HUGE difference...
Re: Nozzle hits the prints but bed is leveled April 05, 2020 11:40PM |
Roberts_Clif
bornlivedie
Thought you had a probe because you have this enabled
Most likely I enabled that by mistake.
I use a M502 Factory Reset and M500 Save Settings and I place M420 S1 After the Last G29.
Not any more I now use
Tried that, but fails too.
bornlivedie
I had so many starts fail that using Baby steps to start seems 2nd nature unless 1st layer is laying correctly, and have had almost no fail prints sense.
bornlivedie
This sounds like your bed leveling adjusters are moving.
Re: [FIXED] Nozzle hits the prints but bed is leveled April 07, 2020 10:57AM |
