7.2 Slic3r but I just get junk after the first layer May 01, 2012 09:28PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 01, 2012 09:42PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: 7.2 Slic3r but I just get junk after the first layer May 01, 2012 09:58PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 01, 2012 10:04PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 01, 2012 10:12PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 01, 2012 11:34PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 01, 2012 11:46PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 02, 2012 01:16AM |
Re: 7.2 Slic3r but I just get junk after the first layer May 02, 2012 03:36PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 02, 2012 03:54PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 02, 2012 04:20PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 02, 2012 05:06PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 02, 2012 05:37PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 02, 2012 06:01PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 02, 2012 06:06PM |
// Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
const bool Y_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
const bool Z_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
//#define DISABLE_MAX_ENDSTOPS
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
Re: 7.2 Slic3r but I just get junk after the first layer May 02, 2012 06:57PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 02, 2012 09:11PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 03, 2012 01:39AM |
Re: 7.2 Slic3r but I just get junk after the first layer May 03, 2012 11:21AM |
Re: 7.2 Slic3r but I just get junk after the first layer May 03, 2012 02:45PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 03, 2012 08:02PM |
Re: 7.2 Slic3r but I just get junk after the first layer May 05, 2012 12:27PM |
