How can I improve this print??
Posted by danlad1631
April 16, 2013 09:18AM
Hi, Been trying to get to grips with Skeinforge but decided to come back to Slic3r. I'm new to repraps and Slic3r so any help would go a long way.
I've got a reprappro mendel and am getting these results you see in the pictures. Could anyone advice on what settings need changing in Slic3r?
1. Bad corner. It seems to be really uneven in one corner, the others are not the best but this side is always bad. How can I improve this?
2. Banding on some layer. What causes this and how can I improve it?
3. Finish. The finish seems to be bad, what the best settings to improve it?
Also, can I change the side the prints start from in slic3r i.e. the bottom of the object, not the side?
Thanks
open | download - Bad corner.jpg (476.8 KB)
open | download - bands.jpg (466.9 KB)
open | download - Finish.jpg (292.6 KB)
Re: How can I improve this print??
April 16, 2013 11:26AM
Problem 3 looks like your extruding too much plastic. Check extruder calibration, if calibrated lower the flow amount.
April 16, 2013 11:35AM
I've checked my calibration and it was fine, I'll check the flow amount.
Will a lower number on the flow give less blobs?
Thanks
Edited 1 time(s). Last edit at 04/16/2013 11:38AM by danlad1631.
mcp
April 16, 2013 12:11PM
the ugly corner looks like it did not stick to the bed....
The walls I guess are uneven flow, maybe hobbed bolt or lost steps on extruder. Nothing to get cured in slic3r...
April 17, 2013 06:52AM
Ok thanks for the help, I'll have a look that,
