Hi, I really like slic3r but I've got a dimension problem since the begginnig. With skeinforge, it wasn't a problem.
If I made a part with 30mm outside and 25mm inside, I got in fact 30.3mm and 24.7mm. There is an offset of 0.3mm from anyside... So if I calibrate the machine to be ok with external dimension, the inside is worst...
I tried to play with extrusion witdh and I've got a part with the same dimension but not with a good quality...
So, do we have a way to offset all the perimeters from the value we put in? In fact it's like removing (in my case) 0.3 mm from all the perimeters in XY.
Thanks!
