Hi, my daughter and I have just finished constructing our first printer. It's a maker farm 6" i3 and runs RAMPS(Marlin), pronterface and Slic3r.
I am having some trouble with the config of Slic3r, much of the existing documentation suggests setting up pronterface with "slic3r --load config", but I understand that from 0.9 Slic3r will use an internal wxStore to store the config. I have removed the --load config and setting slicer options from the proterface GUI invocation seems to remember previously set values just fine however it doesn't use them for slicing !
Whatever I do it wants to use 0.4mm (which is what ? the right height for 0.5mm extruder ?) and 200deg.
What gives ?
Also when I print the 10x10x10 test piece slic3r output says it's 28x28x14 but the actual printed part comes out at 15.3x15.3xRubbish.
I got some work to do !!
Any guidance much appreciated!
P
