Greetings,
we have some weird problem with Repetier-Host & Slic3r.
We installed Repetier-Host - loaded Slic3r settings and saved every tab. But when going back to Repetier-Host view the Slic3r settings are inactive and we can´t select the correct profiles.
Any ideas what´s wrong and how to workaround?
OS: Win7 64-bit, WinXP
Administrator rights: YES
Path includes ä or ö: in Win7, yes. In WinXP, no.
Standalone install, no workgroups or things like that.
Pictures were taken from WinXP machine.
Win7 machine had this error:
11:28:13.869 : OpenGL renderer:GeForce 6150SE nForce
>>>>>> 430/integrated/SSE2
>>>>>> 11:28:13.869 : Using fast VBOs for rendering is possible
>>>>>> 11:28:25.009 : Failed to read directory
>>>>>> C:\Users\Hämppy\AppData\Roaming\Slic3r/print (errno: No such file or
>>>>>> directory)
Update 1:
We got Slic3r profile fields activated with inserting manually the path to config files.
However the Slic3r still does not start even the path to Slic3r executable is inserted.
Edited 3 time(s). Last edit at 11/18/2013 04:49AM by Jaba.
