I am working on a hand model which should be printed shell only (as much as possible). It obviously needs support out and inside as well.
I installed the newest Slic3r 1.0.0 RC1, and thanks for the improvements external supports are working fine.
However when I check the "Only infill where needed" option the whole internal space gets filled instead of the vertical or 45degrees plus perimeters only.
In this particular case the model needs to be hollow as match as possible and in general it would save 80% filament as well.
I would accept this function to work just as the normal "outer" support. In some cases one needs removable internal support instead of infill.
Would it be possible to add this function with the same or similar parameters like the "outer" support?
Edited 1 time(s). Last edit at 11/27/2013 05:11AM by jnss.
