SLIC3R prints models roughly 50% taller January 27, 2014 12:15AM |
Re: SLIC3R prints models roughly 50% taller January 27, 2014 04:50PM |
Re: SLIC3R prints models roughly 50% taller January 27, 2014 09:02PM |
Re: SLIC3R prints models roughly 50% taller January 28, 2014 08:32AM |
tmorris9
Is it also making them wider? If so then it's a metric conversion issue. If the width is right then it may be a printer calibration is off.
You could post the gcode, stl file and .ini file so we can get a complete picture.
jbernardis
Is your Z axis calibration correct?
Re: SLIC3R prints models roughly 50% taller January 28, 2014 09:32AM |
Re: SLIC3R prints models roughly 50% taller January 28, 2014 10:36AM |
Re: SLIC3R prints models roughly 50% taller January 28, 2014 03:01PM |
Re: SLIC3R prints models roughly 50% taller January 28, 2014 04:02PM |
Re: SLIC3R prints models roughly 50% taller January 28, 2014 05:22PM |
Re: SLIC3R prints models roughly 50% taller January 28, 2014 06:16PM |
matthew798
If there is an error of .1mm PER layer, after 20 layers there is a whole 2mm error. This would be blatantly obvious as each layer would be progressively thicker, which is not the case.
Re: SLIC3R prints models roughly 50% taller January 28, 2014 06:38PM |
Cefiar
matthew798
No, each layer will be 0.1mm higher than the last layer, no matter what the last layer was (it doesn't magically shrink back). Each layer will still look the same as another.
Progressively means that the amount would change with the number of layers. eg: 0.1mm on the first layer, 0.2 on the second, etc, which would be obvious as the layering would look different between the first and last layer..
Re: SLIC3R prints models roughly 50% taller January 30, 2014 05:08PM |
Re: SLIC3R prints models roughly 50% taller January 31, 2014 02:01AM |
