Deleting models is not deleting RAM November 13, 2014 07:06AM |
Re: Deleting models is not deleting RAM November 13, 2014 09:09AM |
birwin
I have noticed that whenever I delete a model from the window in slic3r, the RAM doesn't decrease. I can load in a Large file (I have been testing it with- [www.thingiverse.com]), And its using about 1.5GB of Memory. Then when I delete the file, this doesn't decrease.
Usually how I work is I will load the models in to slic3r, apply all of the settings and export the gcode file. When it's finished I will delete the model and load in a new one and do the same. Is there a way to tell it to delete the Memory of deleted models? Am I doing anything wrong in the way I switch to new files? I don't really want to have to reopen slic3r every time I work with a new model.
I am using slic3r 1.2.1.
Thanks
Re: Deleting models is not deleting RAM November 13, 2014 09:38AM |
dmould
Does the memory use increase with every new model you load, or is it re-using the previously allocated memory for the new models?
Dave
Re: Deleting models is not deleting RAM November 13, 2014 09:47AM |
Re: Deleting models is not deleting RAM November 13, 2014 02:21PM |
Re: Deleting models is not deleting RAM November 13, 2014 03:42PM |
jbernardis
Does it reach a point where it doesn't run anymore? You just may not have reached the point where it would do garbage collection.
I never notice this as an issue because I don't stay in the program. I very seldom get into the slic3r gui except to change settings. If I do slice something interactively, I get in, load the model(s) slice and then exit. Most of my slicing is done behind the scenes controlled by my host program; I never even see the slic3r screen
Re: Deleting models is not deleting RAM November 13, 2014 11:02PM |
Re: Deleting models is not deleting RAM November 17, 2014 09:40AM |
Re: Deleting models is not deleting RAM November 18, 2014 08:54AM |
Re: Deleting models is not deleting RAM November 20, 2014 11:33AM |
Re: Deleting models is not deleting RAM November 22, 2014 09:51AM |
dmould
I'm not sure that is a satisfactory workaround for a "memory leak" bug :-)
Re: Deleting models is not deleting RAM November 23, 2014 10:04AM |
Floyd
dmould
I just loaded a 61meg STL of the Ford engine block on thingaverse into slic3r v1.2.0 and it only raised the ram level by half a gig. Once deleted the ram stayed at the current level until Slic3r was closed...
Unless you only have 1-2gigs of ram in your machine this is not really a big deal IMO. Just close slic3r and load again.
As a test I just loaded a "normal" size STL about 30 times before I used up half a gig of ram.
Who would load a file 30 times into a slicer software? Again yes its an issue with the software but IMO is not a huge deal compared to the other issues.
