Slic3r 1.2.6 fails to open .STL
Posted by Phael
April 14, 2015 11:30AM
Hello All!
I just have downloaded the new Experimental Slic3r, and both of them, x64 or x86, fails to open any .STL file.
Does anybody experienced the same problem?
The other versions run just fine.
Re: Slic3r 1.2.6 fails to open .STL
April 17, 2015 07:49AM
Yes thats a bug. You cant fix it. Use repetierhost or such with slic3r only.for slicing winking smiley
April 18, 2015 01:56AM
I've had no problems with it at all, opens all my .stl's.
I'm running it on an XP machine.
April 18, 2015 03:35AM
I run the x64 version if 1.2.6, and it opens STLs just fine for me - except that after about 3 cycles of loading an STL, slicing it, and then deleting it from the platter, when I try to load another one it terminates without any messages.
Edited 1 time(s). Last edit at 04/18/2015 11:48AM by dc42.
April 18, 2015 09:37AM
I'm trying to run it on Win 7 64 bit and having the same problem with the program closing when I try to add an stl file to the plater.
Once it's done infilling layers it closes.
April 18, 2015 11:50AM
Flyer2
Perhaps you should log an issue at [github.com].
