1.2.9 partial object sliced
Posted by efa
efa
July 02, 2015 04:50AM
hi,
I downloaded some STL files from thingiverse:
[www.thingiverse.com]
In particular the two files:
revers.stl [www.thingiverse.com]
galka_throttle.stl [www.thingiverse.com]
has some parts intersection, so are no empty surfaces, see shots attached.
Slic3r 0.9.10 and Cura-engine 15.04 generate the Gcode correctly, but Slic3r 1.1.7 and 1.2.9 leave a part (the knob/hyperboloid) away.
Slic3r github web site say as main feature: "STL auto-repair (tolerance for broken models)",
it is a bug in new versions?
I fixed (maybe bad) the intersecting parts with Blender, using Add Modifier, Boolean, Intersect, Apply.
1.2.9 continue to generate a part of the complete mesh. Can I upload the modified .stl or .blend files and someone look at it?
Suggestions?
Edited 5 time(s). Last edit at 07/02/2015 11:34AM by efa.
open | download - 737thr_1.png (249.7 KB)
open | download - 737thr_2.png (188.9 KB)
efa
Re: 1.2.9 partial object sliced
July 05, 2015 07:44PM
here an STL that generate a partial gcode, it is simply the 'revers.stl' rotated by 180 degree for printing.
Attached what I see with Blender and with Pronterface+Slic3r 1.2.9 (1.1.7 do the same, while 0.9.10b works).
Edited 1 time(s). Last edit at 07/05/2015 07:45PM by efa.
open | download - revers_1.stl (337.9 KB)
open | download - leva737_6.png (162.8 KB)
open | download - leva737_5.png (404.4 KB)
efa
July 06, 2015 02:11AM
in the slic3r plater preview seems complete. Does the preview in Pronterface generated by itself, so without using the Slic3r output?
efa
July 06, 2015 07:25AM
here the STL fixed by Slic3r 1.2.9 itself for 'revers_1.stl' 22 errors.
Now 'revers_3.stl' show Manifold: Yes and no errors, but still 3D and 2D view are different than Preview and Layers view.
open | download - revers_3.stl (94.4 KB)
open | download - thr737_slic3r1.2.9_3D.png (82.5 KB)
open | download - thr737_slic3r1.2.9_2D.png (38.2 KB)
open | download - thr737_slic3r1.2.9_Preview.png (110 KB)
open | download - thr737_slic3r1.2.9_Layers.png (40.6 KB)
efa
July 06, 2015 05:55PM
thanks to slic3r developers, I corrected with Blender the normals direction and now the model is sliced correctly.
Edited 1 time(s). Last edit at 07/06/2015 06:25PM by efa.
open | download - revers_4.stl (94.4 KB)
open | download - leva737_slic3r1.2.9_3D.png (115.8 KB)
open | download - leva737_slic3r1.2.9_Preview.png (215.9 KB)
open | download - leva737_slic3r1.2.9_Layers.png (81.1 KB)
open | download - leva737_7.png (237.9 KB)
open | download - leva737_8.png (257.5 KB)
efa
July 07, 2015 12:59PM
here my Slic3r settings
open | download - Slic3r_config_bundle.ini (3.2 KB)
