Slic3r GCode Print via USB Card stops after a while August 17, 2015 02:06AM |
Re: Slic3r GCode Print via USB Card stops after a while August 26, 2015 12:12PM |
Re: Slic3r GCode Print via USB Card stops after a while August 26, 2015 04:10PM |
Re: Slic3r GCode Print via USB Card stops after a while August 27, 2015 07:51AM |
julianh72
I found that Slic3r takes a REALLY long time to transfer the G-Code file to the SD card on my printer. It is much quicker to save the G-Code file to my PC's hard drive, insert the memory card into the PC's card reader slot and copy the file across, and then move the memory card back to the printer.
Hope this helps!
Re: Slic3r GCode Print via USB Card stops after a while August 27, 2015 08:49AM |
julianh72
Hope this helps!
Re: Slic3r GCode Print via USB Card stops after a while August 27, 2015 12:31PM |
dc42
I am not surprised. Data transfer over the USB connection to RAMPS and similar atmega2560-based electronics is slow. These boards use a USB-over-serial connection that is limited to about 25kbytes/sec and has no flow control. There are other electronics that can do faster file upload to SD card, using either a native USB port or an Ethernet port.
