SVG to GIF converter November 02, 2015 09:10AM |
from Tkinter import* from PIL import ImageTk, Image, ImageDraw import Tkinter import threading import tkMessageBox import tkFileDialog from os import listdir #Common Variables counter = 0 running = 0 height = width = 0 lines = [] layerstart = [] layercount = 0 filename = '' #Base window base = Tk() F = Frame(base, relief="sunken", border=1) F.pack(side="left", fill="y") G = Frame(F, relief="groove") G.pack(side="bottom", fill="y") IM = Frame (base, relief = "flat", bg ="black") IM.pack(expand="true", fill = "both") #Functions def LoadSVG(): global filename,lines,layerstart,layercount,height,width del lines[:] del layerstart[:] filename = tkFileDialog.askopenfilename(filetypes = [('SVG files', '.SVG')]) lines = [line.rstrip('\n') for line in open(filename)] layercount = 0 for index in range(len(lines)): thisline=lines[index] if "layer" in thisline: layercount = layercount + 1 layerstart.append(index) if "width" in thisline: w1=thisline.find('width="') w2=thisline.find('"', w1+7) width=float(thisline[w1+7:w2]) print 'width: ',width h1=thisline.find('height="') h2=thisline.find('"', h1+8) height=float(thisline[h1+8:h2]) print 'height: ', height layerstart.append(len(lines)) #print layerstart print "layers found: ",layercount eLayerNum.delete(0, END) eLayerNum.insert(0, layercount) def start(): global filename,running,counter if len(filename) == 0: tkMessageBox.showerror("ERROR", "Load SVG first") return if running == 0: running = 1 counter = 0 threading.Timer(0.1, ConvertIt).start() else: running=0 print "Process stopping" pg.set("STOPPED") def formatstr(number): temp=str(number) while len(temp)<4: temp='0'+temp return temp def DrawLayer(currentlayer,saveimage): global filename,lines,layerstart,layercount if (currentlayer<1) | (currentlayer>layercount): return if saveimage==TRUE: image1 = Image.new("RGB", (700, 700), 'black') draw = ImageDraw.Draw(image1) w.delete(ALL) pixels=int(eHeight.get()) scale=pixels/height yoffset=int((700-pixels)/2) xoffset=int((700-(width*scale))/2) polygons=0 startline=layerstart[currentlayer-1] endline=layerstart[currentlayer] for l in range(startline,endline): line = lines[l] if "polygon" in line: if "white" in line: fcolor='white' else: fcolor='black' polygons+=1 mylist = line.split("points=") mylist = mylist[1].split('"') mylist = mylist[1].split(" ") my_points = [] for x in mylist: pts = x.split(",") my_points.append(float(pts[0])*scale+xoffset) my_points.append(float(pts[1])*scale+yoffset) w.create_polygon(my_points, fill=fcolor) if saveimage==TRUE: draw.polygon(my_points, fill=fcolor) if saveimage==TRUE: fname=filename[:filename.find('.')]+formatstr(currentlayer)+'.gif' print 'saving: '+fname image1.save(fname) print "layer ",currentlayer," polygons found: ",polygons def ConvertIt(): global counter,running if running == 1: counter=counter+1 if counter > layercount: running=0 pg.set('Conversion\nFinished') else: DrawLayer(counter,TRUE) pg.set(str(counter)+'/'+str(layercount)) threading.Timer(0.1, ConvertIt).start() def Show(): currentlayer=int(elayer.get()) #get the layer to show DrawLayer(currentlayer,FALSE) #Canvas definition w = Tkinter.Canvas(IM, width=700, height=700, bg="black", relief="ridge", highlightthickness=0) w.pack(expand="true") #Labels lSvg2gif = Label(F, text="SVG to GIF", padx=5, pady=5) lSvg2gif.pack(side="top") lShowlayer = Label(G, text="SHOW LAYER", padx=5, pady=5) lShowlayer.pack(side="top") #Title F.master.title("Slic3r SVG file viewer / converter") #Buttons bStart = Button(F, text="START/STOP", command=start) bStart.pack(side="top", padx=10, pady=10) bLoad = Button(F, text="Load SVG", command=LoadSVG) bLoad.pack( padx=10, pady=10) bShow = Button(G, text="SHOW", command=Show) bShow.pack(side="bottom", padx=2, pady=2) #Entries lHeight = Label(F, text="Height (pixels)") lHeight.pack() eHeight = Entry(F) eHeight.insert(0, 300) eHeight.pack() llayer = Label(F, text="Number of layers") llayer.pack() eLayerNum = Entry(F) eLayerNum.insert(0, 0) eLayerNum.pack() pg=StringVar() lProgress = Label(F, textvariable=pg, fg="red", font="Verdana 10 bold") lProgress.pack(padx=10, pady=10) elayer = Entry(G) elayer.insert(0, 1) elayer.pack(padx=5, pady=5) #Activate base.mainloop()
