How to avoid strands with printing support February 21, 2016 06:11AM |
Re: How to avoid strands with printing support February 21, 2016 12:11PM |
Re: How to avoid strands with printing support February 22, 2016 07:18AM |
Re: How to avoid strands with printing support February 22, 2016 07:59AM |
Re: How to avoid strands with printing support February 22, 2016 10:38AM |
Re: How to avoid strands with printing support February 22, 2016 11:13AM |
Re: How to avoid strands with printing support February 22, 2016 11:32AM |
the_digital_dentist
Why didn't you print that object flipped over, with the large surface of the part on the print bed? You would not need support material for it at all.
Re: How to avoid strands with printing support February 23, 2016 07:19AM |
Re: How to avoid strands with printing support February 23, 2016 01:35PM |
dmould
I agree with "the digital dentist" regarding printing in multiple parts. I do this frequently with my parts, not only to avoid needing support but also in order to make the part stronger in the direction it is needed - FFF prints are strong in the XY plane but the layer bonding (Z plane) is far weaker. To print a column for example, I will often print two semi-circular sections lying down and glue them rather than build it vertically, which makes a far stronger rod. As I mostly print in ABS, I use acetone to form a chemical bond that is at least as strong as a single part. I also glue parts together instead of using fastenings whenever possible. This makes the design simpler, but of course prevents disassembly so is not suitable for everything.
Dave
Re: How to avoid strands with printing support February 24, 2016 07:39AM |
glsf91
How do you "glue" this with acetone?
And how about PLA?
