I'm printing PLA on an RRP Huxley with Marlin firmware and using a 0.5mm nozzle.
I've calibrated my extruder drive so that when I extrude 100mm of filament, 100mm is used.
I've measure the filament diameter several times and checked it is circular not oval, it is about 1.78 (meant to be 1.75mm).
Plugged all this into Slic3r (0.9.7) but when I print a single walled cube with 0.3mm layer thickness by 0.5mm width I need to reduce the multiplier down to 0.83 to get 0.5mm wall thickness.
I recall reading elsewhere that others have to do the same (of course i can't find those links now).
Is this normal or should I be checking / calibrating something else ?
Thanks, Andrew
Edited 1 time(s). Last edit at 12/17/2012 08:26AM by AndrewC.
