Slic3r 0.9.10b
Using vase mode I sliced a cylinder. It printed OK but had acne; seemingly random little pimples here and there caused by ooze as the printer kept stopping very briefly during the print.
The gcode has lots of G4 P49 (dwell for 49 mS) lines. There are other G4 lines with different delays but 49mS is the most common.
I can't photograph the cylinder but the attached jpg shows the effect on a tapering section of another print exhibiting the same unwanted G4 lines. Tapering exacerbates the problem and has the effect of lining the acne pimples up into a diagonal scar line which is easily visible. Note that the taper in this print is wide at the bottom, narrowing in Z; opposite to a "normal" vase; the cylinder had no taper at all.
Stripping the G4 lines out results in a perfect print.
Ring any bells with anyone?
EDIT: Have just noticed that this happens in non-vase mode also, and have seen a totally "mad" line: G4 P0 (wait 0mS)!
Edited 2 time(s). Last edit at 07/31/2013 07:52AM by threedyprinter.
