Feedrate being set too high
Posted by djohnson
January 09, 2014 06:30PM
Slic3r is generating Gcode with feedrates at the start of the job that are unusually high. I am trying to figure out where it is getting the number from so I can correct this issue. Does anyone know where these values come from? The value I'm getting is "F7800". Is this 7800 mm/s? I have my feed rates set to 40 mm/s in the slicer configuration speed settings.
Re: Feedrate being set too high
January 09, 2014 10:51PM
the speed in G code is millimeters/minute 7800 mm/m = 7800/60 = 130 mm/s - still pretty fast
January 10, 2014 02:27AM
Just checked one of my gcode files with my normal settings and it's F1800 or 30mm/sec . But it's funny the line above that one says F18000 (300mm/sec).
January 10, 2014 04:28AM
djohnson..
That is probably your "travel speed" x "First layer speed".
Z-speed has no settings in Slic3R.
You may not need to worry about it as your max speed is limited by FW/EEprom settings.
Edited 1 time(s). Last edit at 01/10/2014 04:29AM by justcurious.
January 12, 2014 01:43PM
Thanks for the help
January 13, 2014 01:27PM
I'm seeing this exact same issue, but the max speed isn't being limited by my FW settings.
dbjohnson, did you get it working?
thanks
dave
