Print Quality is lacking October 13, 2014 02:47PM |
Re: Print Quality is lacking October 13, 2014 06:11PM |
Re: Print Quality is lacking October 13, 2014 06:36PM |
3dkarma
Check the number of top solid layers in Slic3r - it should be set to 3. If it is, check the extrusion width setting. This should (as a default) be set to 2.2 times the layer height.
As a general comment, it looks like you're over-extruding slightly.
Don't forget to calibrate your filament width and e-steps per mm.
Re: Print Quality is lacking October 13, 2014 07:50PM |
