Z axis don't go down June 29, 2012 03:27PM |
Re: Z axis don't go down June 29, 2012 04:33PM |
Re: Z axis don't go down June 29, 2012 07:52PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Z axis don't go down June 30, 2012 03:05AM |
Re: Z axis don't go down June 30, 2012 03:17AM |
Re: Z axis don't go down June 30, 2012 04:00AM |
Re: Z axis don't go down April 30, 2013 04:15AM |
Re: Z axis don't go down April 30, 2013 06:15AM |
Re: Z axis don't go down April 30, 2013 06:06PM |
Re: Z axis don't go down May 09, 2013 03:34PM |
Re: Z axis don't go down May 09, 2013 04:02PM |
Re: Z axis don't go down May 09, 2013 04:50PM |
Have you set your printer height right?
I think printer settings are corrects (Note : I use a REPRAP Prusa mendel v2 with ramps1.4):
* X Min = 0
* X Max = 200
* Home X : Min
* X park position: 130
* Y Min = 0
* Y Max = 200
* Home Y : Min
* Y Park position : 0
* Home Z : Min
* Z park position (Z-min) : 0
* Bed Left : 0
* BedFront : 0
* Print area width : 200
* Print area depth : 200
* Print area Height : 100
Check if you see a value for z max endstop with M119
Here is what M119 returns:
22:35:56.754 : N4054 M115 *51
22:35:56.772 : FIRMWARE_NAME:Repetier_0.82.2 FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:2
22:35:56.773 : N4055 M220 S100 *117
22:35:56.774 : N4056 M221 S100 *119
22:35:56.775 : N4057 M111 S15 *67
22:35:56.777 : Printed filament:0.00 m
22:35:56.777 : Printing time:0 days 0 hours 0 min
22:35:56.780 : Echo:M115
22:35:56.784 : Echo:M220 S100
22:35:56.785 : Echo:M221 S100
22:35:56.788 : Echo:M111 S15
You could also try disabling software endstop. Or do you have even enabled z max endstops?
I tried to set #define MIN_HARDWARE_ENDSTOP_Z to false but It did not fixed the problem.
Re: Z axis don't go down May 09, 2013 05:15PM |
