DEar Repetier,
If have a Mendelmax 1.5 with electronic of G3D. I have update your last develoment of the Firmware and copied the Arduino AVR / repetier directory over the existibg repetier-directory.
During compiling a got problems with variable 'tZProbeFailed' and other. I do not use the Z_Max_endstop and therefore it gave problems.
When i switched of the Z_Probe-funtion the problems still came. I have changed the files Communication(.H & .CPP) en UI.H and move the Z_probe-variable within the If-then
I have attach the files.
There was also a Z-axis problem; when starting to print, the commando G28 + G1 Z5 F5000 dit not move the Z-axis. The motors were noisy.
Also manual tried this commando combination. separate the commando G28, then some manual moving and then 'G1 Z5' gave no problems.
In the firmware-version 0.83 it is no problem; i have recompiled to check.
I hope this information helps. I go back to firmware 0.83
Greating,
Henny Ribbink
