I normally use Slic3r as standalone as the simplest way to understand issues.
However I tried to do slicing via Repetier but had some experience that confused me.
Repetier found my already stored config files and displayed at buttons as selectable.
However first time I did the slicing Slic3r did not use the selected config file but used -default- settings which is selectable within Slic3r.
I had to press the Configure button and select the specific configuration within Slic3r and then it remembered the settings but different first time.
I intentionally left setting in Slicer Manager empty if this could be important.
Is this occasional behaveour or a bug?
