Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED February 24, 2014 09:58PM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED February 25, 2014 11:29AM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED February 25, 2014 02:09PM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 01, 2014 09:46AM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 03, 2014 05:07PM |
repetier
Ok, latest patch now includes inverted heater control. Hope it works as expected.
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 04, 2014 03:06AM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 04, 2014 10:49AM |
repetier
No there is no special arm thread.
With your stuttering, make sure you increased buffers to something like 32 with 100 subsegments. We now have ram to prevent underruns:-) A bit stuttering directly at the start is normal. That happens when the buffer is not filled up fully but already gets used.
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 04, 2014 10:58AM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 04, 2014 12:14PM |
repetier
With subsegments I meant MAX_DELTA_SEGMENTS_PER_LINE :-) You can go up to 255 there if you like. You have enough ram to do so. 32/100 is what I had running on my delta the last week with great success.
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 04, 2014 12:22PM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 04, 2014 02:40PM |
repetier
That is weird, but I think I have the same problem. Didn't think enough about it when it happened after a print. Reconnected and extruder worked again. But my prints also home and there after the extruder works. So I think it is not G28 but some state we come into that prevents extrusion. For me it was homing after an aborted print. Will investigate that problem along with my other problems :-) But I think it is the extruder position. There is now a safety check to prevent unwanted long extrusions. So I guess the last position of the print in combination with relative extrusion is a problem here.
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 05, 2014 03:42AM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 05, 2014 11:16AM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 05, 2014 11:26AM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 05, 2014 09:22PM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 05, 2014 09:34PM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 08, 2014 09:26PM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 09, 2014 08:35AM |
Re: Arduino Due and Ramps-FD #define HEATER_PINS_INVERTED March 09, 2014 10:40AM |
