I recently made the switch from Windows on my printing laptop to Linux Mint 17 64 Bit. I am thoroughly confused by the Repetier Host I downloaded for this OS. The only slicing engine now seems to be CuraEngine? I swear I had Slic3r on the Windows version.
I decided to start from scratch again and renamed my RepetierHost directory as well as my ~/.local/share/RepetierHost directory. I also backed up and removed ~/.mono/registry/CurrentUser/software/repetier.
I freshly unpacked repetierHostLinux_1_5_3.tgz into my home directory.
Then I ran:
sudo configureFirst.sh
At the end I got this error:
IMPORTANT: You need a recent mono version since the host uses .NET 4.0
If you see the following error message, your mono is too old!
>>> System.Windows.Forms.SplitContainer doesn't implement interface System.ComponentModel.ISupportInitialize <<<
Which seems odd because my mono version is thus:
Mono JIT compiler version 3.2.8 (Debian 3.2.8+dfsg-4ubuntu1.1)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
I then copied the .desktop file to my Desktop and ran it.
When I go to the slicer tab I see only CuraEngine as expected.
As per the instructions I downloaded Slic3r 1.2.9 64 bit and unpacked it in my RepetierHost installation directory
After restarting Repetier-Host I can now click on the Configuration button for Slic3r, but all that does is display the Slic3r help command options in the log window. I swear there was a gui for configuring Slic3r on the Windows version. Or am I crazy? Just wondering if I'm doing something wrong. I'm not opposed to managing Slic3r in configuration files. I just thought there was a gui.
I'm also having a problem with the Firmware EEPROM Settings screen. When I open it up I have no scrollbars. I have to manually modify the epr file and reload it to make changes to my EEPROM configuration. Maybe this is related to my Mono error?
