Problemi Start G-code Host V1.5.6
Posted by maralb
September 26, 2015 03:33AM
with the previous version all ok
I can not stop extrusion during placement
after the command G1 G1 X-75 Y0 F2400 Z0.4
continues always extrusion
this is my Start
; Default start code
G28 ; Home extruder
{IF_EXT0}M109 T0 S{TEMP0}
{IF_BED}M190 S{BED}
G1 G1 X-75 Y0 Z0.4 F2400
G91
G1 E10 F160 ; estruder 10mm for pressure nozzle
G92 E0 ; reset extruder position
G1 E-1 F300 ;retract
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
; Activate all used extruder
{IF_EXT0}M104 T0 S{TEMP0}
; Wait for all used extruders to reach temperature
DELTA Printer - Duet -Touch5" - E3D_V6
Re: Problemi Start G-code Host V1.5.6
September 27, 2015 11:29AM
Not sure what you want to say, but befor
you also need
G92 E0
or it is not clear from what position you want to go to E10
September 27, 2015 11:34AM
G1 E10mm
estruder 10mm to prepare noozle pressure
What is wrong ??
September 27, 2015 11:40AM
Yes, but what was th e E position before that command. -100, -65, 882 ? It is not defined so random results can be expected. Especially if it is the second print.
September 27, 2015 11:47AM
this start, if included in the previous version update
everything's OK.eye popping smiley
You can have an example?
September 27, 2015 11:51AM
Are you talking about the blue line to the left? I thought your extruder is not stopping when you print.
September 27, 2015 11:53AM
Yes
the blue line is continuous extrusion before leaving the absolute cordinates
