Connection Errors Repetier FW + Host December 15, 2012 07:12AM |
Re: Connection Errors Repetier FW + Host December 15, 2012 08:02AM |
Re: Connection Errors Repetier FW + Host December 15, 2012 08:22AM |
Re: Connection Errors Repetier FW + Host December 15, 2012 08:30AM |
Re: Connection Errors Repetier FW + Host December 15, 2012 09:03AM |
Re: Connection Errors Repetier FW + Host December 15, 2012 09:06AM |
Re: Connection Errors Repetier FW + Host December 15, 2012 09:15AM |
Re: Connection Errors Repetier FW + Host December 15, 2012 09:18AM |
14:56:54.665 : start
Re: Connection Errors Repetier FW + Host December 15, 2012 09:54AM |
15:38:21.234 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 15:42:15.112 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 15:42:17.416 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 15:42:17.580 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 15:42:17.598 : Resend:1 15:42:17.598 : Receiving only error messages. Stopped communication.what do they mean?
Re: Connection Errors Repetier FW + Host December 15, 2012 10:02AM |
Re: Connection Errors Repetier FW + Host December 15, 2012 10:13AM |
Re: Connection Errors Repetier FW + Host December 15, 2012 10:27AM |
Re: Connection Errors Repetier FW + Host December 15, 2012 10:40AM |
Re: Connection Errors Repetier FW + Host December 15, 2012 10:59AM |
Re: Connection Errors Repetier FW + Host December 15, 2012 11:09AM |
< 16:58:01.983 : OpenGL version:4.3.0 < 16:58:01.983 : OpenGL extensions:GL_AMD_multi_draw_indirect GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_texture_type_2_10_10_10_REV GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NV_alpha_test GL_NV_blend_minmax GL_NV_blend_square GL_NV_complex_primitives GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_ES1_1_compatibility GL_NV_explicit_multisample GL_NV_fbo_color_attachments GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragdepth GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_lod_clamp GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_OES_compressed_paletted_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_point_size_array GL_OES_point_sprite GL_OES_rgb8_rgba8 GL_OES_read_format GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_vertex_half_float GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control < 16:58:01.983 : OpenGL renderer:GeForce GTX 580/PCIe/SSE2 < 16:58:01.998 : Using fast VBOs for rendering is possible > 16:58:13.893 : omstart < 16:58:13.940 : N1 T0 *27 < 16:58:13.940 : N0 M110 *3 < 16:58:13.940 : N1 M115 *7 < 16:58:13.940 : N3 M111 S6 *68 < 16:58:13.940 : N4 M80 *63 > 16:58:16.139 : SD init fail > 16:58:16.155 : Error:Binary cmd wrong che?????????j?{????? ?i0?j@?kP?l?Z??X`??p?????????????n?????? ?m0?n?@?oP?p?Z??X`??p????????????V?j?{????? ?q0?r@?sP?t?Z??X`??p?????????=?#??n?????? ?e0?f@?gP?h?Z??X`??p??????? > 16:58:16.155 : Resend:1 > 16:58:16.170 : ok > 16:58:16.170 : ok 0 < 16:58:16.170 : Resend: N1 M115 *7 > 16:58:16.170 : Unknown command: > 16:58:16.170 : error writing to file > 16:58:16.170 : Unknown command: > 16:58:16.170 : Unknown command: > 16:58:16.170 : Unknown command: > 16:58:16.170 : Unknown command: > 16:58:16.170 : Unknown command: > 16:58:16.170 : Unknown command: > 16:58:16.170 : Unknown command: > 16:58:16.170 : Unknown command: > 16:58:16.170 : Unknown command: > 16:58:16.170 : Unknown command: > 16:58:16.170 : Unknown command: > 16:58:16.170 : Unknown command: < 16:58:16.170 : Resend: N3 M111 S6 *68 < 16:58:16.170 : Resend: N4 M80 *63 > 16:58:16.170 : Unknown command: > 16:58:16.170 : Unstart > 16:58:18.370 : SD init fail > 16:58:18.370 : Error:Binary cmd wrong checksum. > 16:58:18.573 : Resend:1Resend:1 > 16:58:18.588 : ok < 16:58:18.588 : Resend: N0 M110 *3 < 16:58:18.588 : Resend: N1 M115 *7 < 16:58:18.588 : Resend: N3 M111 S6 *68 < 16:58:18.588 : Resend: N4 M80 *63 > 16:58:18.588 : ok > 16:58:18.588 : ok 1 < 16:58:18.604 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs > 16:58:18.620 : FIRMWARE_NAME:Repetier_0.71 FIRMWARE_URL:[github.com] P?????????????????`?????????h?q?j??Y???n????a?q??H???8S?+?k?q??n?q??????H????d?q??H???8S?+?n?q??a?q??????H????g?q??H???8S?+?a?q??d?q??????H??#??n?????? ?e0?f@?gP?h?Z??X`??p?????????????j?{????? ?i0?j@?kP?l?Z??X`??p?????????????n?????? ?m0?n@?oP?p?Z??X`??p????????????V?j?{????? ?q0?r@?sP?t?Z??X`??p???????start < 16:58:18.620 : N7 M220 S100 *70 < 16:58:18.620 : N8 M221 S100 *72 > 16:58:20.804 : SD init fail > 16:58:20.850 : Done saving file. > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Un?nown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: > 16:58:20.850 : Unknown command: < 16:58:20.850 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknow? command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: > 16:58:20.882 : Unknown command: < 16:58:20.882 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.897 : Unknown command: > 16:58:20.913 : Unknown command: > 16:58:20.913 : Unknown command: > 16:58:20.913 : Unknown command: > 16:58:20.913 : Unknown command: > 16:58:20.913 : Unknown command: > 16:58:20.913 : Unknown command: > 16:58:20.913 : Unknown command: > 16:58:20.913 : Unknown command: > 16:58:20.913 : Unknown command: > 16:58:25.780 : Unknown command: > 16:58:25.780 : Unknown command: > 16:58:25.780 : Unknown command: > 16:58:25.780 : Unknown command:
Re: Connection Errors Repetier FW + Host December 15, 2012 11:31AM |
> 16:58:16.170 : error writing to file or > 16:58:20.850 : Done saving file.
Re: Connection Errors Repetier FW + Host December 16, 2012 04:42PM |
Re: Connection Errors Repetier FW + Host December 16, 2012 04:49PM |
Re: Connection Errors Repetier FW + Host December 17, 2012 11:01AM |
Re: Connection Errors Repetier FW + Host December 17, 2012 11:46AM |
*/ #define EEPROM_MODE 0 /** Comment out (using // at the start of the line) to disable SD support: */ #define SDSUPPORT 0
17:46:22.501 : start 17:46:22.533 : N0 M110 *3 17:46:22.533 : N1 M115 *7 17:46:22.533 : N3 M111 S6 *68 17:46:22.533 : N4 M80 *63 17:46:22.548 : start 17:46:24.732 : SD init fail 17:46:24.732 : Free RAM:768 17:46:24.732 : Free RAM:747 17:46:24.763 : error writinstart 17:46:26.963 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 17:46:26.979 : SD init fail 17:46:26.979 : Free RAM:719 17:46:26.979 : error writistart 17:46:29.178 : SD init fail 17:46:29.178 : Free RAM:717 17:46:29.178 : error writingstart 17:46:31.370 : SD init fail 17:46:31.370 : Free RAM:717 17:46:31.370 : error writstartMaybe this could help....
Re: Connection Errors Repetier FW + Host December 17, 2012 11:57AM |
//#define SDSUPPORT 0
Re: Connection Errors Repetier FW + Host December 17, 2012 12:43PM |
18:32:23.752 : Free RAM:1373 18:32:23.767 : N0 M110 *3 18:32:23.767 : N1 M115 *7 18:32:23.767 : N3 M111 S6 *68 18:32:23.783 : FIRMWARE_NAME:Repetier_0.71 FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:1 18:32:23.783 : Free RAM:1372 18:32:23.783 : N4 M220 S100 *69 18:32:23.783 : N5 M221 S100 *69 18:32:23.799 : N6 M111 S6 *65 18:32:23.814 : N8 M80 *51 18:32:25.374 : Resend:9 18:32:25.561 : Resend:9 18:32:25.764 : Resend:9 18:32:25.983 : Resend:9 18:32:26.170 : Resend:9 18:32:26.373 : Resend:9 18:32:26.622 : Resend:9 18:32:26.825 : Resend:9 18:32:27.075 : Resend:9 18:32:27.168 : start 18:32:27.168 : Free RAM:1381 18:32:27.215 : Free RAM:1375 18:32:32.972 : Free RAM:1366
Re: Connection Errors Repetier FW + Host December 17, 2012 02:03PM |
Re: Connection Errors Repetier FW + Host December 17, 2012 02:17PM |
Re: Connection Errors Repetier FW + Host December 17, 2012 03:43PM |
Re: Connection Errors Repetier FW + Host December 17, 2012 05:20PM |
Re: Connection Errors Repetier FW + Host December 18, 2012 02:28AM |
Re: Connection Errors Repetier FW + Host December 18, 2012 05:28AM |
Re: Connection Errors Repetier FW + Host December 18, 2012 05:43AM |
Re: Connection Errors Repetier FW + Host December 18, 2012 06:17AM |
