Repetier Firmware / Gen 7 - Heatbed always on January 04, 2013 03:58AM |
/**************************************************************************************** * Gen7 1.4.1 pin assignment * ****************************************************************************************/ #if MOTHERBOARD == 71 #define KNOWN_BOARD 1 #if !defined(__AVR_ATmega644P__) && !defined(__AVR_ATmega644__) && !defined(__AVR_ATmega1284P__) #error Oops! Make sure you have 'Gen7' selected from the 'Tools -> Boards' menu. #endif //x axis pins #define X_STEP_PIN 29 #define X_DIR_PIN 28 #define X_ENABLE_PIN 25 #define X_MIN_PIN 0 #define X_MAX_PIN -1 //y axis pins #define Y_STEP_PIN 27 #define Y_DIR_PIN 26 #define Y_ENABLE_PIN 25 #define Y_MIN_PIN 1 #define Y_MAX_PIN -1 //z axis pins #define Z_STEP_PIN 23 #define Z_DIR_PIN 22 #define Z_ENABLE_PIN 25 #define Z_MIN_PIN 2 #define Z_MAX_PIN -1 //extruder pins #define E_STEP_PIN 19 #define E_DIR_PIN 18 #define E_ENABLE_PIN 25 #define TEMP_0_PIN 0 #define TEMP_1_PIN 1 #define HEATER_0_PIN 3 #define HEATER_1_PIN 4 #define SDPOWER -1 #define SDSS -1 // SCL pin of I2C header #define LED_PIN -1 #define FAN_PIN -1 #define PS_ON_PIN 15 //our pin for debugging. #define DEBUG_PIN 0 //our RS485 pins #define TX_ENABLE_PIN 12 #define RX_ENABLE_PIN 13 #define E0_PINS E_STEP_PIN,E_DIR_PIN,E_ENABLE_PIN, #define E1_PINS #endif
//------------------------------------------------------------------------------ #elif defined(__AVR_ATmega644P__) || defined(__AVR_ATmega644__) || defined(__AVR_ATmega1284P__) // Sanguino // Two Wire (aka I2C) ports uint8_t const SDA_PIN = 17; uint8_t const SCL_PIN = 18; // SPI port uint8_t const SS_PIN = 13; uint8_t const MOSI_PIN = 5; uint8_t const MISO_PIN = 6; uint8_t const SCK_PIN = 7;
Re: Repetier Firmware / Gen 7 - Heatbed always on January 04, 2013 04:22AM |
Re: Repetier Firmware / Gen 7 - Heatbed always on January 04, 2013 12:05PM |
