No, there are no simulated pins.
If you are only talking about handling extruder position check extruder.cpp where we have the function responsible for extruder selection (selectExtruder I think it is named). Or write a new g-code that does it and lets it run before/after gcode selection, so you can write is as event in a separate file not messing up with existing code.
Temperature control is hardwired to be on same board. It was never meant to be run externally, but all is handled in extruder.h/cpp so modifying the routines to send data to external board instead is not that difficult. Just replace all routines doing this with corresponding send commands to send data to board or to pull data from the board like current temperature.
Visit us on
Facebook and
Twitter!
