If you use DRYRUN Heaters should be disabled and reverse disabled if DRYRUN pressed andicons should mirror that state.
But you never know with Heatbed icon as it stays enabled (power is removed ok) so when you return from DRYRUN you cannot be sure if the icon is correct if you want to start heating.
W7/64 Host 1.65
Edited 1 time(s). Last edit at 10/24/2015 05:28AM by justcurious.
